Genos or PSR-SX, which would you pick?
Shaggy
Administrator
For the Yamaha arranger crowd, if you were buying today would you stretch for a Genos or go with one of the PSR-SX boards and keep the change?
Curious what the real difference is once you are actually playing it every day.
If I was an accomplished musician and a performer, I would choose GENOS or even explore the KORG range.
However, just a hobbyist keyboardist, I will stay with the PSR-S and update soon to the PSR-SX
BTW . Nice to see you on board Shaggy participating. You are normally quiet in the background.
What's your story?
What keyboard (s) do you play?
Are you in a band?
Ray
Neither.
My Korg Pa5X is vastly better, for me at least than either the SX or Genos.
I played a 5X then a Genos, then the 5X.
Chalk and cheese.
The Genos 2 was definitely better built and sounded better than the Genos 1 but apart from the Acoustic Piano the Korg blew it away.
The 5X is built like a tank, it is quick to learn the OS, there are dual style controls and the menu diving is shallow.
The Genos has never tempted me, but it's a hobby for me and I barely scratch the capabilities of the SX I have, though I do enjoy it.
Between Genos and another? I'd probably be more tempted by the Pa5x, if only to experience the difference.
From my point of view Genos 2 has better keybed, SA2 voices, ensemble voices, aftertouch and 2 more registration memories, but also much higher price, so I shall probably stay with my SX720. For my hobby playing at home it is fully OK.
Lacko
Canada
For most hobby players, PSRsx series is probably good enough; heck the mid level korg PA700/PA1000, the PA1000 has HDMI out *and* channel after touch! (and share the exact same sound library as the PA4x)
The PA5x is incredibly well built, and has a nicer screen (and frankly is more aesthetic) than any other arranger out there.
But to each his own (obviously); I can't chain registration sequences together on the Korgs, and for the trumpet ensembles and fast bowed orchestral strings, DX7 sounds, acoustic guitars, and pipe organs prefer the Genos2 (but the PA5x and G1 are no slouches either); but for Hammond organs, 80's poly synths, drums and electric bass? I prefer the PA5x/PA4x/PA1000.
But since I *need* registration chaining, I have no choice.
But you judge for yourself:
Here's the same midi file, Fever, optimized for G2 and PA5x, and then also compare a mega enhanced version (using megavoice) running the original file through Yamaha megaenhancer:
Fever remapped for G2 instruments:
Fever remapped for PA5x instruments:
Fever midi file now modified for mega voices:
incidentally I *love* the grand pianos on PA5x; I wish they had a proper felt piano and proper upright, but for me, the PA5x pianos beat the G1 pianos. G2 is a slightly different story, but they're pretty close there.
Mark
Thanks for your views on both.
I differ since I find Yamaha brass strained and harsh and strings like a cat on heat.
Yamaha Genos keybed is very cheap and nasty v the 5X.
To each their own.
Not being a Yamaha fan I have never got my head around Registrations and your Registration Chaining might as well be Klingon to me.
Can you explain in terms that this old guy dan follow?
Canada
Sure thing Biggles! And for what it's worth, even though I prefer the Yamaha woodwind, strings and brass, (and steel string guitar... Korg has a slight edge on nylon; both are good for Electric) I prefer the Korg piano (which is sad for Yamaha... a company founded on piano), as well as drums, electric bass, and drawbar organs and pad synths. I work in a store with both, so...
Registrations allow me to play with both hands, and do voice/patch changes and fill ins (and even change fingering/split point ranges on the fly). Basically, imagine tweaking your keyboard to play exactly a moment of a song (intro, verse1, verse2, chorus, bridge, pre chorus 1, 2 or 3, guitar solo, ending) and those snapshots? Those are registrations.
For example, my "Don't Stop Believin" vid, for the most part I'm using full keyboard: playing the left and right hand like a piano; usually octaving the bass so that the pinky plays the bass guitar and the thumb plays the lowest piano note; until later in the song when it's synth brass, no piano, the left plays bass only. But during the guitar solo, I need the pitch bend, so then the bass gets folded into the left hand acmp, freeing my right hand to solo.
Obviously it's a simplified bass at that point, since I'm not manually playing it during the solo (just left hand chords), but you'll only notice if you *really* pay attention during the guitar solo.
You can also setup anything... vocal harmony on/off, and what type, chord split point and finger at each section; tempo changes, timing changes (doesn't even have to be the same style... my Top Gun Maverick Demo literally uses 4 completely different styles throughout; my Pirates Medley uses 5 different styles, 4 of them 4/4 and one 3/4!) and you can do fade in/fade outs between sections. You can even change the midi setup on the Genos2 (only the Genos2 has this) so that if you use a midi loopback to get 8 voices (6 right 2 left) instead of the normal 3 right and 1 left, you can even assign different voices using different channels of your initial setup midi file... all changed via registration.
Hope that helps ellucidate,
Mark
Betzi
