What model keyboard do you have?As an absolute beginner to the keyboard world, I’m hoping that I can get some advice as to how to start learning to play. Are there any instructional videos, or books that you could recommend?
I’ve got a Yamaha EZ 310, which I think is an arranger. It’s got 61 keys so obviously not a full piano keyboard.What model keyboard do you have?
Is it a DP or Arranger?
Do you want to learn ACMP style playing chords left hand or Piano style playing the bass staff with left hand?
Do you have any background knowledge of music theory and reading notes? Perhaps from a previous instrument?As an absolute beginner to the keyboard world, I’m hoping that I can get some advice as to how to start learning to play. Are there any instructional videos, or books that you could recommend?
None at all. I think the last time I touched a musical instrument was the recorder at primary school, nigh on 66 years ago.Do you have any background knowledge of music theory and reading notes? Perhaps from a previous instrument?
In that case if you will accept advice from a fellow beginner?None at all. I think the last time I touched a musical instrument was the recorder at primary school, nigh on 66 years ago.
Much appreciated Biggles.Place your left hand little finger on a C.
Place your middle finger of your left hand on the E
Place the left thumb on the G
Press the notes down and hold.
How is your maths because at this point I want you to count the unplayed notes between the little and middle finger, then count the unplayed notes between the middle finger and thumb.
Now place the little finger of the left hand on any note.
Using the number of unplayed notes you learned above use them to place the middle finger and thumb.
This method works for any Major chord.
By doing the same counting process for a Minor chord you will find that the middle finger has moved one note left.
This also works for all Minor chords.
It is way easier to learn and use than a Chord Chart.
Once you have become used to playing Minor and Major chords come back and we can explain about inveraions.
Initially learning to play chords and to play scales is all about muscle memory, it is the boring side of learning but overall it will speed up your learning.
TIPS
When you try to play a song for the first time, slow down the Tempo, speed it up in stages when you free confident.
Little and often, often works the best.
As a (very) late starter I recommend the 'three book system' -----the first book starts with simple explanations of what you need to know-----at that point, with fingering , chord and note naming all noted in the piece. Each book moves it on with ever increasing difficult pieces and less assistance. The thing is that the songs are all well known with many contempory ones, indeed the system is upgraded with new pieces regularly to keep it relevant for new learners. The idea is that you can play songs right away---super simple to start with. This is a real encouragement to practice. TAKE lessons at some point------its worth every penny, you need your guru to be a believer in the system for adults, and someone who likes the same music that you do. Makes difference in the overall experience. You will not aim to be a concert pianist, probably not even take grades, but you will enjoy it and come out being able bash out a song. I continued to take lessons after the basics and found that really moved it on.As an absolute beginner to the keyboard world, I’m hoping that I can get some advice as to how to start learning to play. Are there any instructional videos, or books that you could recommend?
One of the most recognisable intros ever written….If I may add couple more thoughts from another beginner?
Play music you like and you'll not only play more often, but you'll get more enjoyment out of it.
Also don't make the mistake I did by trying to play songs or arrangements that are too advanced for your skill level. (It took me a while to finally admit Riders on the Storm is NOT a good choice for a novice LOL.)
