Hammer 88 PCB
Canada
Yes, I have thought of that. I'm trying to find someone who can do that. The USB plug came loose & I tried to repair it myself and soldered off the vias trying to get the broken pins out. My local music store just got back to me and said they would be able to order a new one, but it's back-ordered at the moment. It could take awhile. Thanks for the reply.
Tampa Bay Area, Florida
Okay, that sounds like it may be a relatively easy fix. I would start by obtaining a new USB Type B socket like this but please note, this link is actually for 5 pieces. I didn't spend any time checking for better prices but these are far cheaper than a new PCB and they are readily available.
https://www.amazon.com/RUIAN-Connec...6216f9826bce19875ec772&qid=1779735894&sr=8-16
Next, follow the damaged tracks back from the socket location to where you can scrape away the surface and expose good copper. Carefully solder individual wires to the new socket and leave enough to be soldered to the exposed tracks. Make sure they match the original wiring configuration. Don't worry too much if the new socket attachment lugs don't match the old ones. Once the wires are soldered to the socket, it can be epoxied into place but before doing this, it would be wise to make sure everything works first.
Hope this helps.
Al
Betzi
