Help!!!!!!!
westfield massachusetts usa
I am looking to get a keyboard for xmas,but i want one that has lots of recording capabilities,lots of different instrumental sounds,73 keyed and up ,semi weighted, and under $600 please any suggestions:confused:
humm... loads of good sounds = a workstation... around 600$ hmm....
Try looking at Korg trinity, Triton LE, Korg TR
Sweden
If you're really lucky, you might be able to find a used Triton Extreme. I just checked Ebay, and found some 88 key versions for about $700, so you might be able to find a 73 for $600 if you're lucky.
USA
Triton LE sounds pretty good for a x-mas present. Its a good workstation and many popular keyboardist uses or used one.
Newmarket, Ontario, Canada
If you can find a used one cheap enough, take the Korg TR over the Triton LE. The Triton LE is the light version of the Triton; after the Triton, Korg made the Triton Extreme, and the TR is a light version of that.
ScreenPiano
