I have and unused Cubase 7 which came with my instrument when I bought it new some years back.
I've already downloaded and installed the USB driver and the remote tools software on my computer.
So far everything seems fine and the connections are there.
If I install Cubase now, is that it? Can I only install it on one device?
Reason I'm asking is this is more or less a trial run to see if I am going to be able to work it.
If I need to replace this computer at some later date, does that mean I have to buy a new copy?
If that is the case, maybe I'll wait a bit. Meanwhile I'd be content to be able to just have the MIDI data via USB converted to audio for playback on my computer.
Can anyone recommend a simple app I can download just to do that?
