KORG keyboard
Weird isn't it...
People join these forums for advice and then ignore the advice given to them.
And they usually reply with quite rude and unnecessary short snotty comments with Exclamation marks!
Snotty Twat!
Weird isn't it...
Snotty Twat!
The Op is probably going to be one of those “they came, they asked, they went” brigade never to return.
Why do we bother when a quick Google search finds that there is an Indian version of the very keyboard.
The Pa700 & 1000 also had/have Oriental versions available from new.
Canada
To answer the OP. there are multiple style packs that can be installed into EK50... however, it looks like Indian isn't one of the options, unfortunately. Biggles is correct, a Yamaha i500/i600 would probably be your best bet at that price point
Mark
I dont respond to 1st time posters because 90% of the time you never here from them after the 1st post.
oldman-newpiano
