Korg pa300 organ sounds
kirkcaldy scotland
Despite disabling the 'effects' on my Pa300----still getting a pronounced Low frequency oscillation on organ sounds---and not just on the 'drawbar' option. Anyone know of any download, or tweak that can fix this. Thanks
kirkcaldy scotland
sorry should have been more precise----getting a sound bite is a bit of a struggle for me currently. SO, its like the rotary sound, very slow coming and going just like the 'slow rotary' -----but I have disabled all effects. irritating on 'local' but really irritating when playing with others where the volume comming and going becomes obvious.
Is slow rotary built into the organ program. Check to see if there is actually a dry organ program that you should be using.
It could also be a lousy chorus/vibrato effect in the organ that is turned on. Turn chorus/vibrato off and see if it goes away. If that is it and it is also built into the organ see if there is a an organ program with chorus/vibrato not baked into the sample.
kirkcaldy scotland
thanks for that, I suspect its built in. Haven't found a 'dry' setting. All effects 'off' ---I await return of my EK50 to see if its the same ---reportedly they have the same sound sets althought the EK50 a bit less---but basically should be similar.
Thanks for your time----will let you know how it goes.
kirkcaldy scotland
Hi Dave, yes, thanks for the 'steer' -----in the FX section there is a choice between 'dry' and 'dry/wet'------didn't see it first time -----its at the very bottom of very small print buried in numericals-----so have opted for DRY ----only tried momentarily but it seems to be working-----odd that it is not included in the 'effects' on/off ---but there we go.
Thanks again.
Richard Papps
