Korg Pa4x, Pa5x and Pa1000 - software bargain
£305 for two bundles.
No thanks, way to expensive.
As it is the Global Sounds pack is the standard others are judged by, and it is cheaper.
Did you forget to apply the 20% promo code? It works out at £120 for the downloadable version and £124 for the boxed version.
I'm not sure why you would require two bundles as I doubt if any would work satisfactorily on your Pa700.
Your reading skills could do with improving.
Practice reading my signature and you will see I have a Pa5X.
Tampa Bay Area, Florida
I did see that you have a Pa5x, which would account for one bundle, if you had decided to buy it.
You are correct in the sense that I did not notice that the Pa700 referred to in your signature was a prior possession. This makes it even more strange as to why you would require two bundles if you only have the Pa5x.
Upgrading from the 4x to the 5x doesn't come with a relaxed style, I see!
oldman-newpiano
