ok i tried a bit - didn't get much time today - something weird happened .. now only Fill-in 2 is triggering for both Var 1 and 2 ..
I think you should take some time, because the Var button isn't the deciding factor in which fill is triggered before style switches to the variation change.
With the default settings Cue Mode "immediate, current measure", Autofill "Current", it is the CURRENT variation that triggers the fill-in type of that variation that is active before a styles variation will change. As soon as a Var button is pressed with Autofill active, the "Current Variation" is still the variation before the button press. Then the fill type of the "current variation" is triggered, and only then the change of variation to another new/next variation will occur!
Triggering the fill of the current variation only makes sense in this way and not otherwise. For triggering the correct fill, instead of using autofill, an individual trigger should be considered. For an authentic progression of a performance this also is possible without dedicated fill buttons missing on the Pa1000.
Example Autofill-Test - how autofill works:
Sequences with Autofill enabled, Cue Mode "immediate, current measure", Autofill Mode "CURRENT VARIATION":
1. User starts StylePlay with Var1 and then press Var1 --> Fill1 is triggered
2. User press Variation2: --> again Fill1 is triggered and is ok, because its current running var before changing variation is var1
3. User press Variation2: --> Fill2 is triggered, because its current var is var2
4. User press Variation1: --> Fill2 is triggered, because its current var is var2
With minor modifications, the autofill test reveals that:
- Fill1 can be triggered by pressing either the var1 button or the var2 button (positions 1 and 2).
- Fill2 can also be triggered by pressing the var2 button as well as the var1 button (positions 4 and 3).
This is because, for triggering the fill, it's not the var button being pressed that determines the variation change, but rather the current var being active before a var button is pressed.
Thus, any of the four var buttons can be used, for example, to trigger Fill4 or to trigger any other fill.
1. User starts StylePlay with Variation 4 and then press Var4 --> Fill4 is triggered
2. User press Var3: --> Fill4 is triggered and is ok, because its current running var is var4 (before changing variation)
3. User press Var4 to play var4 for one bar
4. User press Var2:--> Fill4 is triggered and is ok, because its current running var is var4 (before changing variation)
5. User press Var4 to play var4 for one bar
6. User press Var1:--> Fill4 is triggered and is ok, because its current running var is var4 (before changing variation).
PS: Autofill hasn't simplified playing with the Pa1000. Since the Pa1000 lacks dedicated fill buttons, authentic performances in StylePlay mode are complicated without remote control via MIDI control changes for the fill-ins, as the simultaneous pressing of the Autofill and Var buttons is anything but user-friendly.
