Late to the MIDI game
Hi, I’m looking to setup a midi patch controller for my MONTAGE 8, Roland 730 and Roland DS88. I’m thinking about using some MAC software to send patch changes to minimize my patch selection work. I’ve heard about some bluetooth Midi connectors that I hear would have to be connected to all 4 devices. I’ve also read about FCB controllers being pretty good.
A concern I have is PPOF (potential points of failure) while playing live. I know the Midi standard has been around for decades but stability is a must for me.
Does anyone have any advice on hardware/software that they have had success with? Horror stories would also be helpful. I don’t want to invest a lot of $ and then have it be a real nightmare to use.
A best case scenario would be for me to somehow input a set list and that list would contain all of the patch changes for each song. Scroll down 1 row, or mouse click and the new patches would be sent.
Sorry for the verbosity but I wanted to clearly explain my goal and the fact that I’m a MIDI newbie.
Here's my setup with a Mac Mini M2 controlling the lot. Get a program called MIDIfire to manage the routing. I run it with a 16 port powered USB Hub I bought from Amazon for about $30. And I use Logic Pro XI as my DAW.
Stability is largely dependent on trial and error in configuration to kick out the bugs as they arise. Once you've spent a few weeks or months to kick out the bugs everything becomes quite stable and predictable.
Hi, I’m looking to setup a midi patch controller for my MONTAGE 8, Roland 730 and Roland DS88. I’m thinking about using some MAC software to send patch changes to minimize my patch selection work. I’ve heard about some bluetooth Midi connectors that I hear would have to be connected to all 4 devices....A concern I have is PPOF (potential points of failure) while playing live. I know the Midi standard has been around for decades but stability is a must for me.
One way or another, all 4 devices have to be connected... and for maximum stability in a gigging situation, I'd go with 5-pin MIDI connections to the boards. They are much more rugged than the USB connectors, and 5-pin connections are not susceptible to any kind of interference (and they can reliably run over longer distances as well, though that's probably not an issue here). There are 5-pin-to-bluetooth adapters (CME being the go-to brand there), but a wireless technology is not going to be as rock-solid as a hard-wired connection.
But here's a problem you may run into: The VR-730 has a very limited MIDI implementation, and one of the limitations is that you can't change its registrations via MIDI Program Change. You *can* change the individual tones, though, so that would be the approach you'd have to take.
For the wiring, you can either daisy-chain the 3 keyboards, or you can use a MIDI Thru box...
...for daisy-chain, you'd wire Mac to MIDI In of the first keyboard (using an interface like the Roland UM-One); use a MIDI cable from the MIDI Thru of the first keyboard to MIDI In of the second; and another MIDI cable from the MIDI Thru of the second keyboard to MIDI In of the third. In your case, the Montage has a dedicated MIDI Thru connector; the Juno has a MIDI Out with an option on the board to change it to function as a MIDI Thru; but I don't think the VR-730 has a MIDI Thru option, so it would have to be last in the chain.
...for the Thru box approach, you'd wire Mac to thru box (e.g. connecting that Roland Um-One to something like a MIDI Solutions Quadra Thru), and then run 3 MIDI cables directly from the thru box, going directly to the MIDI In of each of the three keyboards.
(There are some cheaper alternatives to the Roland and MIDI Solutions boxes, and at least one single box that combines both functions, but with maximum stability as your goal, I'd go with the tried-and-true well-proven name brand stuff, and it's not like any of this is going to break the bank.)
Although Gary is using Logic to control his gear, for your purposes (sending Program Changes to the boards during live performance), I would not use a DAW, it will be simpler to do the things you want by using a program designed specifically to manage sounds in live performance (regardless of whether the sounds are in software or hardware). On the Mac, you'd be looking at Mainstage, Gig Performer, or Camelot Pro.
Remember, daisy chaining DIN MIDI introduces lag in the circuit. And the USB MIDI standard has been around in stable configurations for over 2 decades now. I find mainstage has problems addressing channels ie. it responds to every device connected. It's really not designed to work with multiple keyboards and controllers.
Not much at 3 devices (and totally insignificant if you're just sending Program Changes). But sure, that's an advantage of using a thru box rather than daisy chaining.
Sure, but for live gigging, where it's an option, 5-pin remains superior for the ruggedness of the connection (less likely to be accidentally pulled out, less likely to fail over time), the imperviousness to ground noises, and for signal that doesn't quickly degrade at longer cable lengths. So I guess it depends on your interpretation of what constitutes maximum stability.
Hmmm. Well it *should* respond to every device connected, (wouldn't it be a bummer if it didn't?), but you should be able to differentiate by MIDI channel and possibly by port, no? Is Logic any different?
Though in this case, he is not looking for Mainstage (or whatever software) to respond to input FROM the connected devices, but rather send Program Change data out TO the connected devices, if that makes any difference in what you're talking about. Though ultimately, he might want to do both.
FWIW, a quick search shows lots of videos on the subject...
I've only played briefly with Mainstage since it's just another Hohum Virtual instrument with a somewhat limited range of keys to select from. If you can set it up with splits and layers I'd love to hear about it, but in my brief experiments it seems to output the same tones regardless of which controller on my network I'm playing.
Logic Pro allows you select individual patches and ports and channels and audio routing for each and every track.
Canada
Yamaha arrangers have something called "Registrations"; I mean you already have your keyboards, but this was just more of an FYI in case, down the road, you wanted a keyboard with changing soundscapes on the fly.
I bought a CVP with registrations to replace my old setup of 2 arrangers + dx7 + a CLP digital piano specifically because I got tired of setting patches up every time I wanted to play.
No need to consider new gear for that. The recallable user Performances on his Montage are capable of changing not only the board's own sounds, but also sending Program Changes to his attached devices.
Thanks to everyone’s comments. I am actually writing my own tkinter Python Set List tool. It basically operates by:
1: reading in a master song list in CSV which has the song title, channel number, msb number, lab number and patch number.
2: the user can then create of songs that are unique among all sets.
3: within each set listings the user can drag songs from one row to another for re-ordering.
4: clicking on a row within a set will automatically send the patch changes for each of the 2 Rolands and 1 Yamaha.
I have the Python code for this gui app already written and am just researching the final step of communicating patch changes using MIDI.
AllKeyys56!
I have a friend that uses "MainStage". That will require a computer onstage (MacBook). It can handle all of that. The biggest point of failures is power. I would recommend a UPS when performing live. Plug everything into it except maybe your amplification because that draws a bit of power.
Toronto, Canada
I've been gigging since the mid 80s with MIDI DIN, with racks of modules, a couple controllers, keyboard synths. For simplicity and reliability, avoid a computer, but sometimes - one *wants* to make it complicated! :) It's been a while since I worked with a Montage or DS, and I'm pretty sure one or both will send multiple PCs in 'performance' mode.
Of course the trick is in the planning and programming. I set it up with a 1-button program change to do everything I need, and program the gear to work. Although I'm not doing the song Bat Out Of Hell anymore, which needed 7 or 8 patch changes. And I also limit my gear, I would never bring TWO 88key multitimbral keyboards, but that's just me. You can use MIDI to get the most out 1 of your 88keys and leave the other at home. After gigging for so long, ease of use and setup/teardown is as important as the sounds. YMMV
I have experienced a lag with MIDI and USB, but that's the fault of the tablets or computers. I have never experienced 'lag' with a 15ft MIDI cable between controller and synth. If one notices that, than I'm sure one can hear the difference between nitrocellulose and polyester finishes as well.
I also use a Boss GT1000 for sustain/modulation/processing, keys and guitar at the same time, it's better than a Key Largo IMHO. Did you know the GT1000 sends 4 MIDI PCs with one footswitch? Others like the Helix do the same.
These days I'm using a rack synth with variety of controllers, including a JV30 from 199?. Modern 'controllers' generally feel like shit, with smaller keys and crappy action. Check out the smaller DS series to see what I mean.
Best of luck!
Thanks for everyone’s responses. I just finished my Python setlist app and it sends patch changes just fine. My only challenge is that the patch “name’ does not get changed along with the patch on the 730. It just shows the base class like “organ” or “synth”. I don’t want to play note to check so it looks like I need a lookup table where the device,channel, msb, lsb, patch are stored along with the patch NAME. I’m thinking after the patch send, throw up a message box with each keyboard listed and the patch name that’s loaded. My click just selected the song so my hand will already be there to click the ok button. I’m going to have to parse this Beast up though. I have one huge application Class that’s over 3k lines. Ugh.
Of course, a Macbook would have its own battery backup built-in. :)
Betzi
