In theory that works, but as I'd mentioned, the old keyboards used a pair of 1/4" inputs, but the current ones use the minipin aux jack... very prone to crackling and snapping of the pin. But yes, it can be done.We have the same again with the Op, they came, they posted & zilch.
Back to topic, how about using the Aux Input?
Feed the second Mike into a small mixer and feed output into the Aux Input, adjusting the Gain to achieve line level of supply?
1. As I said earlier, you're asking for trouble running 2 mics split into a single jack with VH.1. "Anyway, as for no problems with VH, you never both use it at the same time (actually, the male vocal is so quiet it's almost invisible)" - My vocal is rather strong to use VH simultaneously with my singer-girl!
2. "PSR740 is from 1999, not even this millenium" - And I have no interest to pay for any modern PSRs - there is nothing interesting in them. If I want the modern voices - I use GigLad software https://deltarray.com on my Windows pocket. And to accompany my friend's Karaoke singing PSR 740 is quite good in now century!![]()
Hmmmm... Stereo output of mics is the necessary thing?? Once again! I worked with such connection about 10 years! On the different scenes, with different amplifiers and speakers!... Nobody guessed I used Y-cable for 2 mics!The problem with the parallel hookup of twin microphones to a single pair is that one mic will always try to drive the sensing element of the other microphone and forget about stereo output.
Mixer is the way to go.
As a matter of fact, we did; the issue was exactly what HappyRat said; one mic always ended up overpowering the other and driving the VH; when the other tried to put their mouth closer , it ended up flickering the VH notes (which sounded *really* bad, as you can imagine; because it wasn't sure of the amount of pitch to shift *to* the target note; which resulted in the harmony notes randomly flickering up and down by 5th & 6th intervals and sometimes octave+)""....
*That* is the trouble I was talking about; one vocal overwhelms the VH
Really? Seems you never used 2 mics with the same VH! Here is the very old record (using analog camera) — VH is singing with us every "Hafanana" and all choruses! One VH for both of us simultaneously! Both mics are connected to the same port of PSR using Y-cable!
My modest present for you - my MIDI file (I made it for PSR 740) "Hafanana" in ...wow! In 2001!!! On the one track you can see SYSEX-s for Chords and ON\OFF for VH!![]()
Holy cow, you're right!Doesn't the Studio Logic Numa X range have multiple microphone inputs ?
I think it may even allow up to 4 dynamic microphones to be connected. Check to be sure before you click 'buy it now' though.
