Lost sound quality?
Discussion in 'alt.steinberg.cubase' started by K Andresen, Dec 25, 2003.
  1. K Andresen
    K Andresen Guest
    Somewhere between listening to the output of Cubase VST 5.1r1 on my Macintosh
    and the burned CD I am losing sound quality. I'm using the built in CD burner
    in my iMac. What gives? Could it be the sampling rate?
    1. Advertisements
  2. K Andresen
    aJax Guest
    Losing quality? What do you mean? Are you getting noise on the final cd, is
    it all compressed into the centre, what?
    Try to be more specific.
    aJax, Dec 25, 2003
    1. Advertisements
  3. I don't know. Could it? Are you working in Cubase at a rate other
    than 44.1KHz ?
    Are you playing the CD through the same amplifier and speakers as you
    use to monitor your Cubase work?
    Exactly what difference are you noticing in the sound?
    CubaseFAQ page www.laurencepayne.co.uk/CubaseFAQ.htm
    Laurence Payne, Dec 26, 2003
    1. Advertisements
You'll need to choose a username for the site, which only take a couple of moments (here). After that, you can post your question and our members will help you out.
