Medeli A810 Keyboard
Ad
Advertisements
The manual doesn't say, and there's very little information about loading and saving user style files. The only thing I can suggest-- aside from contacting either Medeli themselves or a dedicated Medeli user group-- would be to see if you can save one of the built-in styles to a user style file, and if so then see if you can view it in a program such as MixMaster. If MixMaster can't understand the file format, then you might need to use a hex editor to view the file's raw data and see if you can figure out the format from that.
