Need Help with my keyboard display!!!
Some few days ago, even after I turned my keyboard off, the display still didn't go off.It goes off only when I unplug it's switch.I really need help on how to fix this, please help me
Probably a bad switch. Two options,
Option 1: have the switch replaced
Option 2: unplug the keyboard when finished.
Personally, I'd go with option 2. Reason: it problem could turn out to be something more complicated and expensive to fix. If you have a workaround, use the workaround and move on.
chuckletta
