Newbie question about Yamaha power supply
XFF
Sydney, Australia
Hi all, I’m new here. I recently purchased a Yamaha EZ-220 secondhand with a generic 12V power supply. Then we moved, and lots of things got mixed up. Now I have two 12V power supplies, and cannot remember which was used with the keyboard. Problem is, if I use the wrong one, and its polarity does not match the keyboard’s, it might damage it!
And nowhere could I find any info about its polarity setting – not in the manual or even on ChatGtp! It only refers to the standard models from Yamaha that can be used, but that doesn’t help me. Would someone with a Yamah be so kind to check their power supply for its polarity?
Just Google what power supply that model takes -- and then look up the specs of that power supply.
= Done!
( Or ask AI.... )
Old No7
This is what powers my psr s650
240v AC in . . 16v DC out to keyboard.
CA, USA
I did a search, and found:
The official power adapter for the Yamaha EZ-220 portable keyboard is the Yamaha PA-130 / PA-130A AC Power Adapter.
Power Specifications
• Input: AC 100V–240V, 50/60Hz (worldwide voltage support)
• Output Voltage: 12V DC
• Polarity: Center-positive (+)
• Connector Type: Standard DC barrel plug (compatible with 5.5mm x 2.1mm specs)
It should say something like "Output: 12V DC." Amp doesn't matter much. I don't think the keyboard needs more than 500 mA. Most power adapters are more than sufficient.
The polarity is important. + for the center, - for the ring, similar to in the photo posted by Rayblewit should work (but not 16V DC).
Betzi
