Nordstage 3 midi roland edge
torino
Ciao a tutti vorrei collegare in midi la keytar roland edge con la nord stage 3 76hp.
Lo scopo é utilizzare i preset della edge dalla nord stage 3. Quindi la nord prende i preset roland. Inoltre ogni preset roland edge deve essere associato a un preset della nord stage 3 76hp. Di conseguenza in live quando cambio i suoni dalla nord si associano i suoni roland edge.
Qualcuno può aiutarmi? Grazie
Denver, CO
Translate gives me this...I hope this is helpful:
Hello everyone, I would like to connect in midi the keytar roland edge with the nord stage 3 76hp. The aim is to use the edge presets from nord stage 3. So the north takes the Roland presets. In addition, each Roland Edge preset must be associated with a nord stage 3 76hp preset. Consequently, in live when I change the sounds from the north, the roland edge sounds are associated. Can anyone help me? Thank you
For Nord Programs to also change the which Roland sound is being called up on the AX-Edge, you'd use the Nord's EXT section to send a Program Change to the Edge. That sound would then be able to be played from the AX-Edge keyboard and/or the Nord's keyboard, as desired.
As for physical connection, you'd run a 5-pin MIDI DIN cable from Nord MIDI OUT to roland's MIDI IN. The cable can be up to 50' long. You can also use something like a CME WIDI Jack to make that connection wirelessly over bluetooth.
Brian Nicholson
