OT: Voicemaster Pro Settings - Male Vocal
Discussion in 'cakewalk.audio' started by Chris Forsyth, Oct 24, 2004.
  1. Anyone out there using Focusrite's Voicemaster Pro - that might have some
    "favorite" settings on the inline processors on the VMPro for recording a
    male pop/rock vocal? I am just starting to use it a lot, and I love it -
    but as is probably prudent - I am most afraid of overusing anything. The
    vintage harmonics for example are really great - but seem a bit hard to
    tame. Anyway - any input from anyone out there with this unit is much
    Chris Forsyth
    1. Advertisements
You'll need to choose a username for the site, which only take a couple of moments (here). After that, you can post your question and our members will help you out.
