- Joined
- Nov 23, 2022
- Messages
- 40
- Reaction score
- 19
Folks
I've been playing a few years but have never played with other musicians. However I've decided that's got to change
so have set it as an objective for early next year.
One problem I have is deciding on an amp that would be suitable for group practice. I'll be playing blues, classic rock, jazz and 'celtic rock' ( think Fairytale of New York or Whiskey in the Jar'). I'm not thinking of gigging.
I don't know what to do about an amp. I have a couple of bass amps and cabs from a previous life. My first choice would be my Ashdown 4x8 cab with a Warwick Gnome 200w amp, not for the volume just because the amp is so small. However the cab, despite being a 4x8, weighs a ton (22kg) which may rule it out as I don't fancy carrying it up and down stairs every time I go out. It's also a bit overkill for what I need.
I also have a Peavey Minx 50 watt 1x10 combo, but the sound quality isn't great for keyboards.
I'm thinking of getting a small and light 10 inch active FR PA speaker like an Alto TS or TX, or alternatively a passive 1x8, 1x10 or maybe even 1x12 that I could use with the Gnome.
Ideally I'd like something that weighs less than say 10kg, handles the full range, can sit on a stand and looks like a vintage Fender Tweed (just because). Not really sure about the budget but I don't want to spend too much.
Any suggestions?
Any suggestions?
