Preset drum patterns from keyboard to DAW
Finland
Is it possible to transfer the preset drum patterns from the Technics SX-KN930 to MIDI tracks in, for example, the Cakewalk program? By playing notes on the keyboard, I can connect to the program and record them on a MIDI track, but is there a way to get those preset drum patterns directly?
Yes it is possible, but only if your Technics can send MIDI data from Drums track (most of all it is #10 MIDI Channel) via MIDI interface
Zolder.B
Hoi
You can not only record the drumtrack but also the accompaniment tracks in your DAW
Tip: arm in your DAW midi channels 10 too 16 ready for recording.
START a drumsession on the 930. Verify the tracks for acc 1 -2 -3 and the drum track can be find in track 16. Take note you only have GM level. You can configure the midi settings if you want see manual page 111. I am using this system on a kn6000 and cakewalk (not from bandlab but it can work also) if your drum sounds like a piano then you'!ll have to change midichannel 16 into channel 10.
Good luck
gohardrgohome
