I assume it can because most Casio keyboards can be coaxed into outputting the accompaniment to an external sequencer as long as you enable their output on the corresponding channels and set up those tracks to record.
However, if you want to be certain, I'd advise that you ask your question on
Thanks you for your reply.
I shall do what you suggest.
I know some of the older Yamaha keyboards do send the accompaniment on separate midi channels and for me has been an added bonus,which provides an opportunity to change the voices,at will,
via the daw....cubase in my case,later.
Speaking of older keyboards,the only Casio I've ever owned is the CZ101.....now that's going back a bit.....
