Small keyboard/synth Recommendation
We are a trio looking to add sounds via a keyboard/synth and not wanting to drag my 88 key Roland in and out of gigs and small venues. Looking for something very portable with a variety of sounds (instruments) with the ability to transpose up and down as needed - rudimentary keyboard skills at best. Thanks in advance!
Virginia
Kurzweil pc4 88
You might wanna check out which one of the Yamaha Reface versions might work for you.
ScreenPiano
