Songbook Pa5x
Soryt
Genos2 / PA5X / YC61
Netherlands
Is there a place where the newest songbook can be downloaded ?
Since update 1.4 my songbook gives wrong styles at the selected song title and alot of title are dissapeared
Songbook is integral with the OS.
The Songbook that you created is basically a database file that Songbook refers to.
I try reloading from your Save All file.
If the problem still persists then I suggest you raise the matter in the 5X section of the korgforum where there are vastly more 5X users than there are here.
Richard Papps
