Styles for Korg PA300
My Korg PA300 Arranger maybe too old now but I'd love to install some new 'styles'. Does anyone know a good source?
Apparently its possible to create one's own styles but I reckon that would be too much for me. Has anyone on the forum actually done it or can point me to a video tutorial ?
regards to all...
Is where you will find the free styles, simply select the 300 to display those that are compatible.
As for creating from scratch has many online video tutorials covering the subject, but that are probably not specific for the 300 but the process should be similar.
Kris Nicholson created this
Occasional contributor her Qui Robinez has dozens of video tutorials so do search him out and bookmark his pages.
Good luck
London, U.K.
Hi John,
I have the perfect place for you to go for your styles and it's totally free. A young French Guy named Dopamine used to have a Korg PA Arranger (600 or 300). He created a file with literally hundreds of styles, pads and sounds that loaded into the keyboard (in effect filling every available space on the keyboard). He has now moved on to other keyboards but kindly kept the Website running for anybody interested. The software will definitely load into your PA300 (I even loaded it into my PA4X).
Here is a Link to the Website. The File you require is Dopamine 2.6, so do a 'save all' on your PA300 and then download and load the Dopamine File.
I would recommend this software to any Korg owner, it's brilliant and it's free. I would be amazed if you were not impressed with it.
Chris
p.s. Finally, please come back to the Forum and let other Members know how useful the software has been after using it.
London, U.K.
Hi John,
It's over three weeks since I posted a Link to the Dopamine software, and to date you do not appear to have loaded it.
That's perfectly fine, as it's entirely your decision if you use the software or not.
I had a PA600 and found the software to be incredibly useful, others may not. The PA600 is still in the family, as it's
now used by my nieces. I went on to purchase a PA5X.
I wish you luck in finding any styles you are looking for.
All the best,
Chris
emmecciq
