Synth Recommendations Needed, Please
Hi! I've been using an Alesis QS7 since it debuted in 1996. When my original died, I replaced it with a used one via ebay. I believe I'm on my fourth one. It's dying and I've decided it's time to join the modern age and upgrade, which is where YOU come in.
I'm okay with new or used, and am grateful that money is not a significant factor. If, for example, I determine that a Nord Stage 4 is the best choice, I can/will spend the $5,500. That said, as I no longer gig regularly, I'd prefer to spend a lot less. :)
** My number one requirement is EASE OF USE. It must be INTUITIVE. I want to be able to locate and/or call up sounds quickly and easily. Ditto for transposing, splitting, and simple tweaking.
** Semi-weighted keys
** 73/76 keys (not 61 or 88)
** Lightweight
** Ability to easily load 3rd party sounds. I love the idea of using Narf or similar, where custom sounds/programming has already been done.
** I primarily play classic rock and assume any keyboard recommended will have all the vintage sounds. The vast majority of tunes I play use acoustic pianos, electric pianos, and organs. That said, I'm not overly particular about how "good" the vintage sounds are. Which you probably figured out since I've made do with a 30-year-old keyboard till now. I'm sure any of the popular synths will sound significantly better than the Alesis.
If you've read this far I really appreciate it and hope you can steer me in the right direction. Thanks!
Harvey
Drspanky
