The EC5 pedal
Fairborn, OH
Wanted to say thanks to all that had comments on the EC5 pedal being used on other Korg boards. Some one suggested I call Korg USA to see if the EC5 pedal would work on the Korg PA 1000, as it does on my PA4X. First, calling Korg USA is useless. There is zero knowledge about nearly anything. One individual said the Korg EC5 pedal does not work on all Korg Boards, just the 4 & 5. So I'm still trying to see if the pedal can be programed to the Korg 1000 before I buy it. More later.
Chuck, Ohio
PA1, PA2, PA3, PA4
The lack of response is not surprising.
This image of is the Pa4X rear panel.
This one is of a Pa5X
You can clearly see the socket geometry for the EC5.
There is no such socket on the Pa5X.
Nor is there an EC5 socket on a Pa1000
If the EC5 does work with the Pa1000 and 5X then it will have to have an adaptor to convert the EC5 plug into a USB plug.
I am not aware of any such adaptor.
Tampa Bay Area, Florida
Chuck, Ohio
PA1, PA2, PA3, PA4
Here's a link to someone using an adapter for the EC5 and Pa5X. Unfortunately, it's not in English.
I don't know if there is a US supplier but here's one in Germany. https://www.usbmidi.de/
Betzi
