Two Studio monitors vs a single keyboard amp?
Monitors are way better at home irrespective of what keyboard you are using.
You have had plenty of suggestions and if you can be bothered to search the forum then you will find hundreds of posts on the subject of “what monitors should I buy?”
It is far to easy to post a question than to research yourself.
If you need stereo, buy two. If you can be happy with mono, buy one. If you need studio monitor sound, buy monitors. If you want more „comfortable“ sound, buy keyboard amplifier.
Lacko
Ohio
I use a single keyboard amplifier and am very happy with the way it sounds in my small studio(one side of my small living room). I'm not going to need anything with a large wattage to fill my rather small space. I'm also not planning to do any gigs at bars or anything like that so I don't really haul any of my equipment outside of my home. When I perform at my church, I use their Yamaha digital piano which is hooked up to their sound system thus eliminating any need to bring my equipment. Other than my three ring notebook with my sheet music, I travel light!! In April, I will be upgrading my current amplifier to a Fishman loudbox micro.
Henk Wolleswinkel
