yamaha keyboard psr-e213 repair
My Yamaha psr-e213 keyboard is not turning on , I have tried numerous adaptors , it is still not turning on . can the motherboard be repaired or what can I do to repair it
Ad
Advertisements
Welcome.
Have you put an electrical test meter on the adaptor output to check if there is a voltage?
If the keyboard can be battery powered, does that work?
With a power adaptor that works connected you could try resetting the keyboard. Hold furthest right key down as you power up the keyboard.
Failing everything a new keyboard may well be the way to go, an E213 is a very old keyboard and is not really worth getting a chargeable repair undertaken on it.
