Yamaha Tyros 1 Freeplay styles needed
Sheffield
Hi. I did try downloading the ethereal style from a psr site but it didn't load on the Tyros 1. It was a Tyros 3 rom style so can't have been compatible. I guess they must need converting with some software first. I will try the sites you mentioned though.
Thankyou.
You probably need SFF1 files, I believe the Tyros 3 uses SFF2, a newer format. There's a converter available which might help, though it's doesn't always, in particular with guitars. It's worth a try though. SFF2 to SFF1
Have a look around that site, there might be a software to identify which styles are SFF1 and which SFF2, if not there the Style Database can show you this. That could be useful as you collect more styles.
Drspanky
