Changing flash memory module
Discussion in 'General Keyboard Discussion' started by Clawsman, Nov 2, 2011.
  1. Clawsman New Member
    Nov 2, 2011
    Message Count:
    Hi all!
    This will be my first post :)
    I was just wondering if its possible for me to change my flash memory module. So i can store more songs on it. I have a Yamaha DGX-205. Any help will be much appreciated.
      • Advertising
  2. drewwilliamspiano New Member
    Jun 8, 2008
    Message Count:
    56
    Seattle, WA
    Reference Connecting To a Computer
    68 DGX-205/203, PSR-295/293 Owner’s Manual
    This instrument can access flash memory for storage
    and retrieval of song data: When song files are transferred
    to flash memory media from your computer they
    can be used with the instrument’s performance assistant
    technology or Lesson functions.
    In order to transfer songs between your computer and
    the instrument you will need to install the Musicsoft
    Downloader application and the USB-MIDI Driver
    included on the Accessory CD-ROM on your computer.
    Refer to the Accessory CD-ROM Installation Guide on
    page 70 for installation details.
    ■ With the Musicsoft Downloader You
    Can ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ●
    ●Transfer MIDI songs you have downloaded from the
    Internet or created on your computer from the computer
    to the instrument’s flash memory.
    ➔ Refer to the step #1 – #9.
    The procedure for transferring songs included on
    the Accessory CD-ROM from your computer to
    the instrument is given as an example.
    ■ Use Musicsoft Downloader To
    Transfer Songs From the Accessory
    CD-ROM To the Instrument’s Flash
    Memory ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ●
    1 Install the Musicsoft Downloader application
    and the USB-MIDI driver on your computer
    (page 71 – 73).
    2 Insert the supplied CD-ROM into your computer’s
    CD-ROM drive. The start window
    should appear automatically, and close the
    window.
    3 Double-click the Musicsoft Downloader
    shortcut icon that is created on the desktop.
    This will launch the Musicsoft Downloader
    application and the main window will
    appear.
    4 Click the “Add File” button and the Add File
    window will appear.
    5 Click the [▼] button to the right of “Look in”
    and select the CD-ROM drive from the dropdown
    menu that appears. Double-click the
    “SongCollection” Folder on the window.
    Select the file you want to transfer to the
    instrument, and click “Open.”
    Transferring Song Files From a Computer
    ● Data That Can be Transferred From a Computer
    To This Instrument
    • Song Capacity (max.) Flash memory 99 songs
    (Song numbers 036 – 134)
    • Data Capacity Flash memory 373 kb
    • Data Format SMF format 0/1
    ● What is SMF (Standard MIDI File)?
    The SMF (Standard MIDI File) format is one of the
    most common and widely compatible sequence formats
    used for storing sequence data. There are two variations:
    Format 0 and Format 1. A large number of MIDI devices
    are compatible with SMF Format 0, and most commercially
    available MIDI sequence data is provided in SMF
    Format 0.
    Use the Musicsoft Downloader application with Internet
    Explorer 5.5 or higher.
    • A USB cable is required in order to transfer song files to the instrument’s
    flash memory.
    USB cables can be purchased at an electrical goods or computer supply
    store.
    NOTE
    • If a song or style is being played, stop playback before proceeding.
    NOTE
    • The instrument cannot be operated while the Musicsoft Downloader
    is running.
    NOTE
    q Click the CD-ROM drive
    w Double-click “SongCollection”
    Folder. Double-click “for_CD”
    Folder and click a song file.
    e Click “Open”
    Connecting To a Computer Reference
    DGX-205/203, PSR-295/293 Owner’s Manual 69
    6 A copy of the selected MIDI song file will
    appear in the “List of files stored temporarily”
    at the top of the window. The flash
    memory medium will also be displayed at
    the bottom of the window to specify the destination
    for the transfer. Click the flash memory.
    7 After selecting the file in the “List of files
    stored temporarily”, click the downward
    [Move] button and a confirmation message
    will appear. Click [OK] and the song will be
    transferred from the “List of files stored temporarily”
    8 Close the window to end the Musicsoft
    Downloader.
    9 To play back a song stored in flash memory,
    press the [SONG] button. Use the dial to
    select the song you want to play, then press
    the [START/STOP] button to start playback.
    q Click the “Flash Memory”
    • Quit the Musicsoft Downloader to play back the song transferred
    from your computer.
    NOTE
    • Do not unplug the USB cable during a data transfer. Not only will
    the data not be transferred and saved, but operation of the memory
    media may become unstable and its contents may disappear completely
    when the power is turned on or off.
    CAUTION
    • Stored data can be lost due to equipment malfunction or improper
    operation. For safety we recommend that you keep a copy of all
    important data stored on your computer.
    • We recommend that you use a power adaptor rather than batteries
    when transferring data. The data can be corrupted if the batteries
    fail during the transfer.
    CAUTION
    ●To Use transferred Songs For Lessons
    In order to use songs (only SMF format 0) transferred
    from a computer for lessons it is necessary
    to specify which channels are to be played back as
    the right-hand and left-hand parts. The procedure
    for setting the “guide track” is as follows:
    1 Press the [SONG] button and select the song
    (036 –) residing in flash memory for which you
    want to set the guide track.
    2 Press the [FUNCTION] button.
    3 Use the CATEGORY [ ] and [ ] buttons to
    select the R-Part or L-Part item.
    4 Use the dial to select the channel you want to
    play back as the specified right- or left-hand
    part.
    We recommend that you select channel 1 for the
    right-hand part and channel 2 for the left-hand part.
    f
    r
      • Advertising
Share This Page
