does anyone know
westfield massachusetts usa
does anyone know if there is anyway that you can connect a playstation 3 and a keyboard for any reason .just throwing it out there,i mean the ps3 has a usb slot so i wouldnt be surprised.
does anyone know if there is anyway that you can connect a playstation 3 and a keyboard for any reason .just throwinmg it out there,i mean the ps3 has a usb slot so i wouldnt be surprised.
hehe... no. :D
USB slots on keyboards are used for midi transfer only (USB TO HOST), and data transfer for sounds, styles, samples, saved presets or settings (USB TO DEVICE)
Hi Lala,
If you'd like to record some music from the PS3, you could
Step 1: record it with a voice recorder
Step 2: transfer file from voice recorder to computer
Step 3: convert file to MIDI format
Step 4: transfer MIDI file from computer to keyboard
Does that sound doable?
ekaymusic
Staff online
