I NEED help identifying this.
Hello,
Recently I started on a project, I was gonna remodel an old EVEREX keyboard. Part of this project is to change the cable to usb, I found this connector connecting the keyboard to the 5-pin din cable, but I don't know what the connector is that connects it to the motherboard.
Here's a picture of the connector. I need to know the name of the connector to buy a usb version.
If you have a look at an electronic component supplier’s website then they will have plenty of PCB connectors.
Here in the U.K. I would suggest CPC Farnell or RS Components as the go to website.
Good luck.
sfz5
