WK 6800 Rotary Effect
Northern Michigan
I have a problem trying to find my rotary and chorus effect and that save it to power resume! I have read and read the manual had it once but now am lost! Any help would be great! Thank You!
I can't find a manual for a WK-6800. Did you mean WK-6600, or perhaps WK-3800?
I see from some of your other posts that you've mentioned having a WK-6500, so I'll assume that's what you'd meant to type. :)
Are you trying to use one of the Rotary preset DSPs, or create your own Rotary user DSPs? And are you trying to figure out how to apply the Rotary DSPs to a user tone and save it? I'm not clear on what exactly it is that you're wanting to do, so I'm not sure which part of the manual to look at.
