Accidentally overwrote patch
Does anyone know how to recover a dingle sound patch on YC61. I don’t want to have to reload the factory settings and wipe out all my other patches I’ve worked on.
Thanks
If the yc61 allows you to backup your patches:
1) back them up
2) factory reset the yc61
3) the missing patch should be visible upon reset. Save that one patch, i.e. backup the one missing patch
4) reload the backup from step 1
5) load the missing patch from step 3
1) back them up
Thanks Dave yes great idea!! It does have a flash stick area on the back. Going to give it a try
Similar Threads
