Cables!!!!
Advice needed please:
I need to purchase TOP quality (but not TOP £££!) mono 6.35mm Jack to 6.35mm Jack Keyboard Cables which are at least 6m long.
Need to be hardwearing and gig proof!
What do you use and recommend?
What do you do to your cables that they get destroyed so easily?
I can't recommend anything specific as I generally use generic store brand cables. Electrically they're all pretty much the same.
If you're looking for something special I'd suggest searching http://amazon.co.uk and see what comes up. Also pay attention to the user reviews to see if anything stands out.
They dont get destroyed, they are just old, and were 'acquired' and therefore budget.
Alternatively, Ive been shredding my Fender Jazz Bass with them, whilst chewing on them with my metal teeth, to gain that extra level of feedback......
sorry, sarcasm.
josetabito
