Jenni from the New Forest UK.
I want to purchase a keyboard to take on holiday with me for practising. So it has to be reasonably lightweight, say 5Kg max. for baggage allowance. I need a reasonable range, say 61ish keys. What I do not need is lit keys, masses of pre-set tunes or multiple instrument sound alikes - though I fear I will have little option but to have some. I would prefer to buy second hand as I plan to leave it in Australia for the grandchildren rather than bring it home. Can any one suggest suitable makes and/or models that fit this criteria?
Very many thanks
Jenni
Hi Jenni,
What sort of budget are we talking here? Assuming that you're bringing along a laptop or an iPad might I suggest you simply bring along a cheap MIDI controller like the M-Audio Oxygen 61 and use it to play virtual synths thru your laptop?
That's probably your cheapest, lightest option, though I have to say you probably won't be too happy with the keyboard touch and feel on any of the cheaper options.
Hi Gary,
Thank you for the information. How does this compare to the quality of Yamaha or Casio? It is not a name I am familiar with. Can this machine not be played independent of a laptop or iPad then? As I want to leave something for my grandchildren having a keyboard that can only work through a computer is not really an option. Sorry, but I am showing my ignorance here.
Jenni
Here's an article explaining how MIDI controllers work and what differentiates them from synths.
http://www.howstuffworks.com/midi2.htm
As for playing it without a computer, no it will not make sounds unless it is hooked up to a computer. Think of it as an input device for your computer which acts as the actual MIDI sound synthesizer.
I'd pretty much assume that your grandkids would have regular access to a computer these days since almost everyone does, so they'd still be able to use it after you're gone as long as you installed the software for it. One advantage to using this kind of setup is that you can completely change the sound of the keyboard simply by changing the software you use to drive it.
However I don't really recommend the M-Audio Oxygen line. I use an Oxygen 49 with a laptop at home but I have to say the key build quality is pretty lousy and the only way to be able to play it without it skipping notes is to turn velocity sensitivity off.
Anyway, that pretty much leaves any cheapo Yamaha or Casio as your main choices. They're all pretty much the same though I find the Yamaha's have more natural sounding instruments compared to the cheap and cheerful nintendo sounds of the cheaper Casios.
Offhand my advice would be to simply go to your local big box department store or electronics shop and pick up the cheapest Yamaha keyboard you can find and live with it. 61 notes is pretty much standard and in the lower end of the price ranges there really isn't all that much to differentiate individual models. I'd say anything you can pick up for around 100 UK pounds or so will suit your needs just as well as anything costing two or three times as much.
One final thought BTW.
Since you're flying from the UK to Australia, I honestly think you'd be better off buying a cheap Yamaha while you're down under instead of paying extra baggage fees and undergoing the hassles of packaging it for transport halfway around the globe.
The Australian market is competitively priced for musical hardware and that way you won't have any need for power supply converters once you're down there.
Thanks Gary fory our input - my trips abroad starts in India, so would rather buy in the UK first, Wou sayilltake on board what you say.
Jenni
Sierra Foothills, CA
Just to add to Gary's comment - actually a controller doesn't require a computer; but you would have to have a source of 'sounds' and a computer might be the easiest. Another option would be a small MIDI sound module (there are dozens of them around). For simplicity's sake though, you probably would be better off with a self-contained board. One quick search brought up this one:
http://www.musiciansfriend.com/keyboards-midi/yamaha-np11-61-key-piaggero-digital-piano
61-ish keys, more than one 'voice', touch-sensitive keys, <5kg weight. ;)
:cool:
Welcome to the forums Jenni! Sounds like they've got you've covered, hope you manage to pick up something suitable. Sounds like you've got quite a trip coming up!
Similar Threads
[ Compo ] " Deep Forest " 4
josetabito
