Roland BK5 Changing repeat speed of presets tones such as Saw Impulse (0831) or Flux Pulse (0688)
Does anyone know if it's possible to change the repeat speed of these tones? The current speed is too quick. I want to slow down (particularly) Saw Impulse a bit so that I can use it as the basis for the intro to Dakota by Stereophonics. I have fiddled with everything I can find in Performance Edit, using the Tone Part Edit and Tone Part Mfx. I have tried to get support from Roland but the keyboard is not in the list of keyboards that you can raise a case for. I'm technical so understand about oscillators and so on. Any help would be gratefully accepted ...
The only thing you might be able to do is change modulation LFO frequency or detune a VCO if your board has VA capability. If you don’t see it in the manual then you ain’t got it.
Gary. ;)
Bradders
