Roland RP30 USB-B Question
Philippines
HI,
I've bought me an Roland P30 and do not know what to do with the USB-B Midi port. I've learnd that this device is nor supported by the both Roland apps "Piano App" and "Piano Partner 2".
When I tried it I got this error:
"Midi Device Connection error
Error occured during MIDI connection from your piano [E001] If you are connectiong via Bluetooth, delete your piano from the "settings" menu of your mobile device, and try again. Or try connectiong via USB MIDI cable"
So what could I use this port for?
I tried already to connect it via USB-B to USB-C cable to my Laptop and also to my Samsung Tab Galaxy S8 - but nothing happened. Is there any Windows application or Android App which is supporting this device?
josetabito
