sysx
when i send the yamaha psr 4600 panel settings using a sysx dump to software on the computer it works.
when i send it back sometimes there is no sound - other times there is an echo? the key makes a sound on the release as well as the usual.
what i do is send the settings of each tune set up to the computer. then it remebers all the settings when i play a tune.
thanks all
Similar Threads
