Wasn't allowed to post in Q&A; Keytar advice?
I want to buy a keytar, but do you plug them into amps with the same tech as guitars? How to you plug them in? What do you use, can you use wireless connectors?
Bath or Durham, England
Depends which model keytar you get. Most are MIDI controllers which need a connection to another unit as Sargas describes above. However, the new Roland AX-Synth has a built in sound engine so you can plug it straight into an amp like a guitar, or use a normal guitar wireless system.
Similar Threads
