Assigning the record button?
HI everyone, Im having a bit of a problem. I just bought an Akai Advance 49 and my first impressions are good.
However I noticed that the record button on the keyboard doesn't start the recording in Logic Pro
any help
Thanks
I don't have Logic Pro-- or an Akai Advance 49, for that matter-- but from the Advance 49's User Guide it looks like there's a default setup available for Logic Pro X. Is that what you're using? If that preset doesn't work for your version of Logic Pro, I wonder if you could create a custom setup?
Also, many DAWs have a MIDI-learn feature that can be used to map a particular control of a controller to a particular function in the DAW. I'm not familiar with how Logic Pro works, but I assume it probably has such a feature.
Thanks Michael, I fixed it.
For future reference I went to Global settings on the Akai Advance and changed midi to MPC
JCGlines
