BK-7m Backing Module "matching song" of the Twostep style ??
Hi there!
Does anybody out there have a BK-7m module?
There is a particular dance style from it which represents a real hip-hop/2step chart song I have heard, (probably from around 2010/2011) but I can't for the life of me think what it is called or who sang it!? :confused::confused:
If so please could you listen to the style "Twostep" under the DISCO DANCE category and tell me what real song this matches by artist/song name?
It's unfortunately not listed in the BK-7m's Music Assistant list either!! :(:(
Thanks guys!
If no one can help you then you should try using the Spotify app! It might just recognise the song you are thinking of if they are similar enough.
sfz5
