PA 1000 USB question?
Hertfordshire UK
I have a prog. which is working fine. Pax Magic. Yesterday i noticed part missing, (Set List) but the sounds were still in Direct so I re-installed ok.
As I wanted to save in a larger USB I decided I would downloaded prog. onto this stick, set list did not show so I thought load again to overwrite, did not work. I had also formatted new USB to the Pa.
I can put old USB in Front or Rear slots and set list comes back. seems strange, any ideas please?
Hertfordshire UK
Sorted, uninstalled wiped old save from USB to be sure. I installed again from original on computer to USB then to keyboard , straight in. Logic has it's own surprises.
Staff online
