Yamaha PSRS910 users?
Hi guys anybody here has Yamaha Psrs910, i find this keyboard outstanding ,sounds are top notch ,the only issue i have the 4Variations buttons are kinda hard to change have to press and squeeze hard in order to change variations, it should be changing with just a push,i normally do not use them due to when playing it's no possible to press and squeeze hard ,anybody knows a easy solution ,thanks
It sounds like the contacts for the buttons have gotten worn out from repeated use. If you're comfortable with the idea of opening up your keyboard and trying to service it yourself, you might be able to clean the contacts to improve the buttons' responsiveness. Do you have a copy of the Service Manual? I think it's available at the ElektroTanya website.
