Elkatwin 61
Hello my fellow musicians.
I am kooking for an 1980s analog italian keyboard
ELKATWIN 61
If you or anyone you know of is selling one, please contact me asap
(e-mail address removed)
A little history regarding this keyboard.
I owned one as a teenager and like everyone else sold it many years later only to regret it.
I am hoping someone will come through for me.
Thank you
You read this thread within minutes after I posted - I'm happy to see that.
I just stuck an ad up on Kijiji
Well good luck with your sale. A new fuse holder costs about a buck and ten minutes with a soldering iron to install it.
I'd suggest fixing it up so it at least powers up before you try and sell it.
Since you're selling on Kijiji I'll assume you're a fellow Canuck...
Good day eh? ;)
Yep, I just saw your ad. Eglinton Dufferin area. :D
I'm in Meadowvale/Mississauga myself.
Nobody's gonna offer you diddly on Kijiji unless they actually see it working.
Spend a couple bucks and fix the fuse holder.
Gary :)
Hello, I own a New Elkatwin 61and I'm missing the cap & fuse T1a. Where can I buy one?
Thanks in advance.
Pat
Hi Everybody . I own an Elkatwin 61 synth, it seems to work, but , right now I need to replace some diodes , one on the Pulse Generator. If someone can tell me where I can buy this diode,I would appreciate it very much. Some parts are hard to find. Thanks.
Diodes are pretty simple devices. What are you looking for? Rectifier diodes or switching diodes? Either way your only concerns are peak inverse voltage, max current and switching speed if it's a switching diode. Also in the unlikely event that it's a germanium diode you'd have to replace with a similar type. Otherwise if it's a zener diode then you'd also need to know the breakdown voltage.
Find out those specs and then you can source a replacement from any electrical supply house.
Similar Threads
Elkatwin61 needs repair 4
Ebbetsman
