Extract Bass for any songs
Hi All,
Is there any quick way / technique to extract bass from any songs ? I am presently working on chinna chinna asai from Roja, and want only the bass to be extracted. Is that possible using softwares like - Cubase.
Thanks
If you are wanting to remove only bass notes from a final stereo audio mix , the short answer is mostly "no". If you have editing plug-ins, and you're really meticulous, you can use a parametric EQ to minimize the bass frequencies, but you won't actually remove the entire individual bass line. Rather, you will only cut the predominate frequencies in which you hear the bass line. You can also remove a block of frequencies, but you affect more than just the bass line.
New To V-Stage
