PA 600 USB Pen Drive Problem
When I insert the Pen Drive (consisting MP3 files) to my PA 600 keyboard, it detects. But the pen drive or the files are not visible in the Media Screen. It just shows the KORG DISK selector.
Format the USB stick in the Pa600.
If after loading the files it still fails, try using another USB memory stick.
As the 600 is quite an old design the max capacity of the USB drive you use may well be limited.
Thanks for your reply. But the pen drive option is not showing. Then how will I format? Please suggest. Also, I tried different pen drives. All have the same problem.
Yes, I have had this issue as well for a long time then finally I needed to replace my keyboard, and the issue got resolved. I also searched on many sites to get the solution but I didn't reach a proper solution then my friend suggested me the site techters and I explored the article related to the keyboard. They have a huge collection of tech solutions. I hope this can help you.
New To V-Stage
