Saving settings on psr s650
Rod
Does anyone know how to save settings on a psr s650?
I set the voices the way I want them and when I power it off and on again I have to reset the settings.
I got instructions for setting the one touch setting setups and when I try pressing the memory button with any of the four one touch setting buttons, the screen displays that I can't use that function.
Does anyone know what I am missing?
All I'm doing is trying to save dual voice settings for piano and organ.
Sweden
Hej Rod,
you shouldn't try to save data in the One Touch Buttons.
Try instead of to save your data in the registration memory.
You have 64 memory places (8 bank a 8 places). How to do that, look here:
Memorizing Your Favorite Panel Settings -see page 49 of the Owner's manual
The single steps you find on page 50 of the Owner's manual
Recalling the Memorized Panel Settings - see also page 50 of the Owner's manual
Rod
Thank you so much! That works! I have so much to learn about this keyboard. Each thing makes it more fun to play.
