Sharing is Caring! Rudess & Moore leads for the M50
Sweden
So, I downloaded this pack a few days ago with 32 programs and 20 combis, and found those 3 sounds (2 Jordan Rudess lead sounds, and one Kevin Moore lead sound) in the pack, that I felt like sharing.
I actually did record a short example of one the sounds:
http://www.box.net/shared/i5l0m82o46
(not a very well-played solo, but it was only to demonstrate the sound anyway :p)
Here's the link for the download:
http://rapidshare.com/files/272050739/DTLEADS.rar
(You'll have to scroll down a bit to find them, they're at E096-E098)
If you haven't transferred any sounds to your M50 before, learn from my mistake: Load the sounds into your SD card first, and then into the M50. DO NOT load them into the M50 Editor first! The Editor will synchronize the PCG file with your M50, overwriting all your custom-made sounds with the ones in the PCG, which will cause you a lot of trouble.
While saving the sounds from your SD card to the M50 allows to you choose which sound you want to save, and where you want to save it.
I recently discovered a small issue with the first Rudess Lead sound (JS -Y gives a "permanent" change to the sound), but I've talked with the guy who I got this from, and he's looking into it. As soon as he finds a solution, I'll share it here :)
Hope you'll enjoy the sounds. Happy soloing! :)
