A-33 to control a Motif 6 ?
Hello,
I've just buyed a Motif 6 and I would control it with a Roland A-33. So I can use only the sounds of the motif but using 2 keyboards (The A-33 is very light...).
I want call only 1 user-performance and play a sound with the A-33 and other sounds with the Motif, but I can't use PERFORMANCE because the midi channel is the same.
How can I set different sounds on different midi channel in the same PERFORMANCE/SONG ?
ThankYou very much
Stefano, welcome to the forums. IF you can't find the answer in the Motif manual, then I would suggest that you try posting your question at motifator.com. That site is dedicated to the Motif series, but it is best to try and find an answer in the manual before you resort to posting the question. B3
josetabito
