DGX670B & KORG M50
What can these two instruments accomplish together, and how can I connect them both? I currently have loaded on my laptop the Audacity DAW into which using the USB to host cable I have connected my DGX. How can I connect to the same the Korg and can these instruments in some way work together. I'm new if you can't tell.
If you don't have enough USB ports on your laptop, then connect them both thru a powered USB hub.
The you can record multiple tracks in your DAW and play them back as an ensemble.
Thank you. The lap top does have two usb ports, will give it a try. So much to learn!
